Perhaps I’m missing something or doing something wrong, but it appears that variables are not available for use on the MOVE/ROTATE tool.
Would be nice to be able to assign this value programmatically, but I am forced to assign an absolute value.
Would be nice to be able to assign this value programmatically, but I am forced to assign an absolute value. For example, let’s say I’ve got a body that will be sandwiched between two or more identical bodies, but that sandwiched body’s thickness is defined by a variable.
It would avoid additional steps of having to edit the MOVE/ROTATE command after having selected a different value for the thickness of the part.
Seems like history and variables for the Move tool would also be very helpful. I would suggest that the team working on the videos and help files lead folks to using the pattern tool instead of the move tool whenever possible.
I’d like to move a body a small distance as defined by a variable. In my case it’s to create a cabinet door reveal that is adjustable by a variable. I can’t use Move because variables aren’t allowed. I can’t use Pattern because I don’t need to make a copy. I can’t use Align because I need to move the door AWAY from the alignment by a variable amount. I can’t use Translate because there are no points on the face to select.
Thank you. That’s not exactly what I need to do, but you’ve given me some great ideas. I still wish that the Move tool could be modified parametrically though!
