When drawing in 3d often times the font of the dims is a bit annoying when it is in the lock position and it displays locked. I find the display to be fine but i hate the scale size as it is rather large on the screen and it is a bit annoying while zooming as i work.
I would like to have the option of reducing the size of the annotation font so that is less in my face when i work…
changing the color and or disappearing if it i am not focus on editing the geometry that the annotation is locked on would help…
I expect that it will be a more comfortable use of the screen real state.
It slows me down…
