Using external monitor?
Any one has experience with, how it is to use external monitor to the Ipad Pro when drawing in Shapr3D?
I am considering using Shapr3D as my only 3D program. Since I do not draw complex constructions.
Best
Anker
Greetngs,
I have used an external monitor with good results. I bought a ā€˜Lightning to HDMI’ adapter that worked well with my 2018 iPad Pro. I’m sure you can get a ā€˜USB3 to HDMI’ adapter as well if you have a newer iPad Pro.
-Mike
While I haven’t tried it personally, you should be able to mirror your screen onto a larger monitor to view your work. But the App requires the pencil to touch the iPad screen.
Hi Anker, adding to the already suggested options, you can use a VGA or HDMI cable to connect your iPad to an external monitor to have a larger display.
Here’s a great Apple article on how to go this using an HDMI or VGA cable:
Thank you so much to all of you.
It sounds like it is possible to use an external monitor!
Do any of you know how far it is possible to see the apple pencil ā€œpointā€ on the external monitor, so that it is easier to navigate on the monitor?
You are welcome. AFAIK, the monitor displays what is visible on the iPad and shows all interactions.
If it happens that some edges are cut off or there is some interactions not visible, this can be resolved by adjusting the monitor’s display settings.
I think if you look in the accessibility settings you will find an option that turns on where you touch and tap on the screen. I don’t remember the exact name of the option so you will have to look.
To to Settings, and scroll down until you see the Shapr3D app. Then choose Tutorial Mode. You ā€˜ll need to restart Shapr3D for it to become effective.
Thank you so much, I will try that…
