You either need to write the complete name of the variable or select it in a list which can be a lot of clicking and writing. Also, variable names are case sensitive, I fail to see the need for that.
You can write variable names quickly with just a few characters without having to click y+ and selecting in a list. Saves time and the effort of moving between mouse and keyboard. Case sensitive variable names are hindering and slows down typing.
Faster and more fluent work.
