Bonjour,
Comment puis-je récupérer mes projets faits avec la version Bêta qui n’est plus accessible.
Cordialement
Michel AM
Hello! If you export the workspaces as a Shapr3D file, you should be able to import them back to the current version of Shapr3D, but it may depend on versions. Can you please tell me what beta version are you using?
Hello,
Unfortunately, I can’t tell you which version I was using because when I try to start it I get the following message: The beta version of “Shapr3D Beta” has expired.
On the other hand, when I try to get the latest beta, the TestFlight app tells me that the developer has removed the Build.
Cordially
Michel AM
