Volume information
Is there a way to check the volume of a geometry?
I work in packaging and when modelling a bottle shape, I need to check if it has the required volume capacity.
Thank you in advance for your help.
Sure.
Thank you, Istvan :slight_smile:
Is there a way to set the volume units to ml?
I know how to convert mm3 to ml, but it would be more direct to display the volume in ml when we measure liquids.
Happy to help! Currently you can’t change the units.
