Great start on Drawing capabilities! Can’t seem to get the Radius or Diameter functions to create label/arrow.
Hello,
There are two ways of placing radial/diameter dimensions, please give them a try:
The first is to tap on a circular shape with the pencil then select if the radial or diameter dimension should be shown:
Video 03-12-2021 13 06 -
The second is to select the Radial or Diameter dimension from the Dimensions toolbar in Drawings, then select the circular shape.
Going further, it is not always possible to dimension a round part on the end view. It may be necessary to dimension it in the elevation or even plan view. I think Shapr3D does not yet allow this. As of now it needs a circle or a radius to do so. Looking forward to this.
