Add realistic material finishes, manage overlapping decals more efficiently, and quickly reference geometries on imported meshes.
- New: Bring richer textures to your architectural and interior scenes with new options for brick, Medium-Density Fiberboard (MDF), oak strip and herringbone flooring, and Douglas fir end-grain.
Download a sample model and try it yourself.
Note: You’ll need to update to the latest version to open it. - Improved: Dragging and dropping a decal onto your model now places a new copy instead of replacing the surface material, allowing you to select and adjust each decal directly on your model.
- Fixed: Construction planes and axes can now be created again on imported STL meshes. When using point-based construction tools, select anywhere on the mesh body to pick a point and define your references.
Try these updates and share your thoughts in the comments below. ![]()
