26.210 – Introducing the Thread tool, new sketch tools, expanded import support, and workflow improvements
Dead Shapr3D Team,
This is great!
I just tried it, and these are my thoughts:
  • very intuitive
  • easy to use
  • not so intuitive: Generating a hole and a bolt at the same time. I made a cylindrical whole and a cylinder same diameter (I guess seeing you video it is easier to make the cylinder way smaller diameter and then choose the right thread size), but when I choose both faces and create the threads at the same time, the one on the bolt is rotated by 180° so i had to rotate the bolt 180° so they align. The image i post is without rotating. This also happens when I create the threads one after another.
I’ve tried this thread tool multiple times and my prints are not working at all. The bolt is not even starting. Has anyone successfully made a print? did you adjust measurements on either the bolt or the hole for the nut (receiving body)? Please help
Were you able to make a successful print?
Yes. my M6 hole was precise. A bit snug but still worked fine. X1C and X2D. Both vertical and horizontiI. would like to see tolerance added to threaded holes.
No, tried a few times with different materials and haven’t gotten any to work together yet
i tried m20 thread but its to tight of course when i do section view its so close and there is no room for expansion so that will need to be alliterated
I havent tried, didnt make sense to me without being able to add tolerances.
#Update#
After applying the thread tool to both the bolt and nut, I then tested adding an offset to the nut. I was printing an M10 bolt. I tested with 0.25mm, 0.20mm, 0.15mm offsets. All 3 nuts worked fine so in conclusion, there needs to be an additional offset step added. I haven’t tested with anything less than 0.15mm. By the way, I am printing with a Bambulab P1S
With a bigger bolt, I assume that the offset will be different. More testing to come…
@Jeriz Happy to collaborate on this!
what material did you use? i used PETG and moved the female walls .2 away from the screw and was to tight might try .4
