3 point circle/arc creation
This is what I wish we had.
It would be easier to fit arcs when you can’t snap to center.
Here is the math if you need it…
Date: 05/25/2000 at 00:14:35
Subject: finding the coordinates of the center of a circle
Can you help me? If I have the x and y coordinates of 3 points - i.e.
(x1,y1), (x2,y2) and (x3,y3) - how do I find the coordinates of the
center of a circle on whose circumference the points lie?
Thank you.
Date: 05/25/2000 at 10:45:58
Subject: Re: finding the coordinates of the center of a circle
Thanks for writing to Ask Dr. Math, Alison.
Let (h,k) be the coordinates of the center of the circle, and r its
radius. Then the equation of the circle is:
 (x-h)^2 + (y-k)^2 = r^2
Since the three points all lie on the circle, their coordinates will
satisfy this equation. That gives you three equations:
 (x1-h)^2 + (y1-k)^2 = r^2
 (x2-h)^2 + (y2-k)^2 = r^2
 (x3-h)^2 + (y3-k)^2 = r^2
in the three unknowns h, k, and r. To solve these, subtract the first
from the other two. That will eliminate r, h^2, and k^2 from the last
two equations, leaving you with two simultaneous linear equations in
the two unknowns h and k. Solve these, and you’ll have the coordinates
(h,k) of the center of the circle. Finally, set:
 r = sqrt[(x1-h)^2+(y1-k)^2]
and you’ll have everything you need to know about the circle.
This can all be done symbolically, of course, but you’ll get some
pretty complicated expressions for h and k. The simplest forms of
these involve determinants, if you know what they are:
     |x1^2+y1^2  y1  1|        |x1  x1^2+y1^2  1|
     |x2^2+y2^2  y2  1|        |x2  x2^2+y2^2  1|
     |x3^2+y3^2  y3  1|        |x3  x3^2+y3^2  1|
 h = ------------------,   k = ------------------
         |x1  y1  1|               |x1  y1  1|
       2*|x2  y2  1|             2*|x2  y2  1|
         |x3  y3  1|               |x3  y3  1|
Example: Suppose a circle passes through the points (4,1), (-3,7), and
(5,-2). Then we know that:
 (h-4)^2 + (k-1)^2 = r^2
 (h+3)^2 + (k-7)^2 = r^2
 (h-5)^2 + (k+2)^2 = r^2
Subtracting the first from the other two, you get:
 (h+3)^2 - (h-4)^2 + (k-7)^2 - (k-1)^2 = 0
 (h-5)^2 - (h-4)^2 + (k+2)^2 - (k-1)^2 = 0
 h^2+6*h+9 - h^2+8*h-16 + k^2-14*k+49 - k^2+2*k-1 = 0
 h^2-10*h+25 - h^2+8*h-16 + k^2+4*k+4 - k^2+2*k-1 = 0
 14*h - 12*k + 41 = 0
 -2*h + 6*k + 12 = 0
 10*h + 65 = 0
 30*k + 125 = 0
 h = -13/2
 k = -25/6
Then
 r = sqrt[(4+13/2)^2 + (1+25/6)^2]
   = sqrt[4930]/6
Thus the equation of the circle is:
 (x+13/2)^2 + (y+25/6)^2 = 4930/36
