Hey guys, what is the easiet way to solve this problem? I need my centre of circle to be in the middle of those two points, so they together create symetrical triangle.
You can draw the line in 2 segments and use the equal constraint (lock the ends of the other lines first). That will give you the point to move your circle to. Wait… I see 3 arrows, which two points?
Okay, will try. Sorry, i meant three
You are looking for the centroid of the triangle. Gonna needs some math! Make it into 2 right triangles by adding a line. Use those distances here ->>> Coordinates of a triangle centroid with calculator (Coordinate Geometry) - Math Open Reference
