3D curves
I can’t connect two 90-degree springs to create a 3D surface
Hello, for springs I can suggest you try connecting the face points using the Translate tool
can we swept the two lines together in a 90 degree context
How to use with sweep command
Hello, it will easier to understand what you will like to do if you attach an image sample of your design. Here’s our tutorial video on the Sweep Tool:
I hope this is helpful.
