5.850 - Constraints in mirrored sketches
Model solar surfaces, capture cleaner visuals, and mirror sketches more efficiently with these latest updates.
  • New: Visualization now includes a Solar Panel material to represent solar surfaces in your model.
  • New (Windows): Now you can capture images directly from the modeling space with the Screenshot tool. Screenshots let you customize the grid, selection edges, and tidy up on-screen elements for a clear visual output.
  • Improved: The Mirror tool now automatically applies symmetry constraints when mirroring sketch curves, ensuring consistent behavior and easier edits.
Try them out and share your feedback in the comments below.
There is a problem with the windows update now when you go into Visualization the background environment does not change it only shows as black no matter what environment you pick.
Thank you
looks like the latest updated is working fine now i closed it out and rebooted my machine and now the background environment is showing up correctly now.
Thank you for the update
