5.870 - Introducing Drafts and New Camera Controls
Organize your projects more intuitively with Drafts, present models from fixed angles, and fine-tune visuals and patterns with added control across tools.
  • New: Now you can rotate the camera in fixed increments, helping you present your model from consistent angles.
  • New: Tessellation settings now include low and high quality options for better control over mesh detail.
  • Improved: In the Dashboard, Private is now called Drafts and stays visible only to you, while shared spaces can now be renamed to match team workflows.
  • Improved: Projects with Review links now appear on your account page, making it more effortless to view, open, or unpublish shared links from one place.
  • Improved: Used materials in Visualization can now be reset to default using swipe to delete, or the context menu.
  • Improved: AR view now delivers better performance and visual quality on devices running iOS 18.3 or later.
Try these updates and let us know what you think in the comments below.
I’m not seeing how to rotate the camera in fixed increments.
I’m on iPad Pro.
I assume you need a keyboard for that.
You can test with commands
Thanks very much for the quick answer. I do use a keyboard case for my iPad, so it will be convenient to play with the new features.
