Hello community.
I think there might could be a slight addition to the code of naming objects when they are being copied.
It would make things more intuitive.
As you can see on the objects list, there are multiple objects with exact same name. I arrived to this, because as you can see from the screenshot, I began copying from the center to the right two times, then from the center to the left two times.
I could only pick the right object because their position in the list and I thought I should let you guys know, maybe there is an improvement due here.
Thank you and have a great day!
