Ability to switch tool options with hotkey
Not having to manually select tool options.
If I can double press ‘O’ (or other tools’ hot key) it can switch between Loop and Single without having to manually choose this option with my mouse.
It’s slower manually selecting Loop or Single.
Hi – thanks for the report!
It works like that for many tools (most notably in sketching), but it indeed does not work everywhere. It just came up in a different thread, see my answer there:
