Double tap function for Done button
Hi
Can you supplement so that you can also double tap to close if you don’t want to use the Done button (as in
the sketch tools)
kind regards, Patrick
Hi Patrick,
(there is a reason the S3D-team provided you this template by opening a topic in this category).
What would you want to double-tap? The screen? The iPad-pen? The left/right mouse-button?
Cheers Matt
