The problem: Currently if you are zoomed into an object, and you want to adjust the object or move it by a certain measurement and it’s larger than your zoomed area, you have to select the object and then zoom out to see its properties. It’s tedious.
The Solution: Show measurement boxes in the active screen viewing area.
The Result: You should be able to adjust measurements, move, rotate, etc. an object, without having to move around your viewing area.
