Alignment
Aligning objects in Shapr is a gripe of mine, probably because I have not been able to educate myself sufficiently ?
The challenge looks relatively straight forwards, but, I still cannot get it right.
I have to chassis rails that run front to back of a vehicle, they are all rectangular section. There is a similar front axle, running at 90 degrees to the chassis rails, but sits below and unconnected to the rails. I need to put two rectangular vertical links that connect the axle to the chassis rails. I cannot get the vertical components to align to each component, they keep jumping to the mid section and losing the alignment that I first set in place? Help
I suggest you start with a simple example.
It will be easier for you and us to understand what is wrong.
Here’s an example of aligning to a position away from the midpoint. Hope this helps.
Thank you for taking the time to reply.
Can I upload my design and show you my dilemma?
Mike
I have to agree with you even though I have come to terms with it over the years. Check out this thread and see if it helps…
