I am used to the 2D world of Adobe Illustrator and I’m having a tough time using the Shapr3d sketching tool when it comes to aligning objects. Say I want to draw an ellipse and draw construction lines that pass through the center of the ellipse. I the 2D world I would just use the align tools (see attached) and it is done automatically. If I manually draw the lines in Shapr3d they never seem to be centered. Is there at least a clumsy way to to this sort of alignment in Shapr3D?
Draw the ellipse.
Draw the line so that it approximately goes through the midpoint of the ellipse.
Select line and press “Make Comsrruction”
Select the line and the center of the ellipse.
Select “Coincident” or “Midpoint” depending on what you want.
If midpoint isn’t an option, there must have been another constraint or the ellipse and line aren’t selected properly.
Technically it isn’t an ellipse. I needed a rectangle with rounded corners. In a tool like Illustrator that would be easy. I created two circles, joined them with lines and trimmed away all the unnecessary lines. No constraints ever show when I draw any center lines so I just have to eyeball it. The sketching tools in Shapr3D are like a bad 1990s graphics program. Pretty embarrassing. I did find that I can draw elements in Illustrator and import them, but that is awkward.
Ok that shape is more complicated. That shape does not have a midpoint and I don’t think Shapr3d creates “midpoints” for any complex shape to use with constraints.
Also, you can’t select the midpoint of a line and another line and add a midpoint constraint. This should be added to Shapr3d.
Draw 2 line segments to/ from the center of the circle out of equal distant (you can use the = constraint if needed. Lock the lines. draw a line perpendicular as possible to them and choose perpendicular constraint relative to those lines. move the line to the center of the first two lines. That is one way. You can draw shorter lines over longer lines. Oh and repeat for the center line between the 2 arcs. Tricky use of line segments are sometimes needed in Shapr when dealing with irregular objects
I discovered the easiest way to do this. I just drew a rectangle 4mm x 8mm. I then extruded it through the material and then used 2mm fillets on the corners. Stupidly simple, but I made it hard by trying to use the sketch tools. I’m realizing that it’s best to keep the sketches to basic geometric shapes and then just use the tools like extrude and fillets to do most of the work in the 3D world.
