How would you get the drawer pull in the image below aligned to the center of the drawer along the y-axis?
Here’s an easy way to do it manually.
It’s funny you shared this because it came up in another of my posts last week and I still don’t see a way to use it to accomplish what I’m asking without additional geometry or multiple align commands.
Hey Mike…yeah, anything can be accomplished with enough additional geometry. I thought someone would show me some novel way that Shapr3D can accomplish the move without all of the additional geometry.
We have all of these end and midpoints that are essentially useless unless very specific commands are issued. I don’t understand why we can’t snap to these known objects like in this video I made using AutoCAD (for some reason Loom does not want to play nice with AutoCAD)
In the example above, what I really wanted to do was copy the existing pull from an object that it is perfectly placed on, but there’s no way to do it using the end and midpoints, as seen in the video below. I can insert a construction plane and mirror it, which works, but why can I snap the gizmo to the corner of an object as a start point, but once I use the gizmo, it becomes snap agnostic? It just doesn’t make sense, especially when 90% of the functionality is already baked in.
…and I know…I’ve beaten align to death. Had I never used any other drawing program, it would be a different story.
Well now we have more info
. I agree with you. Would be nice if while using the move tool to move or moving a duplicate, it would give us guides when the center/ edge align vertically or horizontally to nearby objects’ centers/ edges or are distributed evenly across the same. I rely on that capability in several programs.
If I’m understanding correctly I would hide the bodies use sketch of pull and drag it to the side of the drawer sketch meeting the 2 mid points and use the alignment lines to get both x and y centered because you can do it on both planes. Hopefully I understood what you’re talking about it is the middle of the night and I read this and replied on 1 of my many times up during the night
Exactly! I’ve been bagging on a closed door for ages about the lack of a simple alignment, which only moves objects (many can be selected) in one dimension (this may be a construction plane of course). As you say other CAD software have this but shapr3D developers don’t want this for some unfathomable reason … they don’t even tell us why!
Another year gone by and still no simple alignment tool. Looking back, I had a post in Oct 2022 ( Aligning bodies exactly - #8 by Geoffree3 ) showing how easy it was in TinkerCAD ![]()
