I have a circle and wish to align text to the inside of the circle, but have no idea how that can be accomplished. Same as you would see on a Tachometer.
Thank you for Reaching out, what you can do is use project to Sketch the letters on the circle.
Not sure how I can do that, I’ve tried a couple of ways but just seem to duplicate the text. (Using project)
Thanks, I thought I must be missing something as Your example above is all I was able to produce. I’ll try some other tools, that does seem the best solution at present.
Cheers
