Anchor Points and Pivot Points
I am brand new user. I have the trial version on my iPad 5 mini installed with the current iOS installed as of 5-9-22. I am using a 1st generation iPencil. Also, I have not used my iPad before for doing illustrations or 3D modeling (old school PC/mouse user).
I have watched the YouTube video basics playlists.
In the videos, I noticed mention of Anchor Points (AP) and Pivot Points (PP).
Q1- Are they the same thing but given a particular description depending upon the function being done?
Q2- Can an AP be moved to a different place on an object and can they also be “remembered” by the object so it can be used later on in the model process?
Reason I am asking is that for a particular body, when moving I might want to use the custom AP for snapping to a “target” object.
Q3- Can(could) a custom AP be used as an reference point (target) when moving, aligning (other transformations?) other objects?
Is there yet a way to perform the action mentioned in Q2 above?
" Q2- Can an AP be moved to a different place on an object and can they also be “remembered” by the object so it can be used later on in the model process?"
A fixed anchor point would simply workflow immensely, especially when design moving parts that rotate around each other.
