Any Archicad User?
Hi there,
Have anyone tried to import a Archicad file into shapr3d, continue design works and export back into Archicad?
Katy
Hi Katy, I know you can share your sketches from Archicad with the app in DWG/DXF format and also share 3d designs in STL format.
The STL format being an output format it’s a great practice will be to convert the file to the STEP(a better editable format) format using FreeCad before importing in into the app:
https://grabcad.com/tutorials/how-to-convert-stl-to-step-using-freecad
This post is from 2020;it’s now almost 2023…
Was the synchronization done between Shapr3d and Archicad ?
Tks in advance
P.
