do you think you would be doing any new AR enhancements like being able to hide parts from a assembly or being able to move parts away from each other to see inside the assembly.
Yes, that would be a great improvement. also when the AR experience is made does it always export the AR file to be at full scale because I did notice that if you do a AR on a very large part and drop it onto a small room floor it has a tendency to disappear or you have to zoom out to find it but if it is dropped in a area floor larger then the part it comes in pretty good.
Thank you
