Archimedean spiral
Hello,
I’m designing a chuck for my lathe and I need to draw an archimedean spiral.
Is there a quick way to do so in Shapr3D?
I have searched and looks like there isn’t…
Hope this helps.
Two sketches, one on each axis.
Then a revolve.
With manual adjust of the revolve using the grabs, you can make it look how you want.
Thanks for your help. Apologies, I was not clear. The Archimedean spiral I’m looking to draw is as in here:
The radius increases with each increment of a radial angle, I need 7 convolutions (for a lathe chuck). I could design it with lines 3.6 degrees apart from the same center and 0.01mm to achieve a 1mm gap between each convolution but that’s over 700 manual touch points, so I was wondering whether there is anything faster that can be done with Revolve.
Here’s a method that can work. Credit goes to @Tippy for what he shared back in 2021.
I recreated his method here…
And here’s the link from 2021.
That is a nice trick, I like it.
Yes, that seems to work. Many thanks. Now I need to figure out how to draw a spiral with lines 1mm in thickness and 1mm apart, with inner circle of 24mm… I’m playing around with it, but with 7 revolutions my iPad Pro is taking ages to project… It’s going to be a long night :slight_smile:
Agree. And, here’s a BONUS!
A nice way to make a helical spring.
It sounds like you want a clock spring.
1mm thick spring steel, around a 24mm boss and 7 turns.
Drawn with Arcs and then sweep.
Yes, that’s it. I need to be able to control all dimensions. Would you be so kind to show it in a video? If it’s too much trouble, I understand.
Hi
You will not be able to control all dimensions, only thickness of spring material and the height. These you can set on the sketch of the cross-section.
Hi again
For what it is worth, here is the video.
I start with the circle sketched, along with a string of short guide lines with ‘=’ constraint set and the inner two ends fixed. This will allow me to change one measurement to change spring pitch.
NOTE: You can only increase pitch, Shaper can’t decrease it.
The spring is drawn manually with 180 degree arcs.
Then ‘sweep’ the spring cross-section along the arcs.
You can change the dimensions on the Cross-section sketch.
Adjustment of the dimensions video.
Thanks so much, this is just perfect for what I need and I’m glad that others can refer to this too! Very clear video, I could easily follow and draw it. I’m very grateful, many many thanks.
No problem, it was an interesting little exercise in use of constraints.
This has made me think of missing pieces of functionality in sketching.
It would be nice if we could make dimensions a mathematical function of others (establish a relationship between elements of the sketch).
I suppose this would be a case of being able to set a measurement as a variable and then define it in a table.
Next would be ‘Scripting’ which would allow users to automate the generation of patterns, etc.
Have a great day.
