Hello everyone,
I hope someone can help out with some issue regarding creating identical radius.
There is an asymmetrical profile with a 45 degree cut off end. I want to round up the edges equally with a 2 mm radius. When adopting the measurement, unfortunately I’m getting different results as can be seen on the fotos added.
Any ideas how to solve this?
Thanks a lot and best greetings
Jan
Copied profile from the first photo. Don’t see the problem.
With a 90 degree ending of the profile it is no problem indeed. But in my case it’s about a 45 degree ending and in this situation I’m not receiving identically roundings as shown in the draft.
Then what was the purpose of posting this profile? (first photo)
Can you attache the sketch with the profile you have problem with? Or even better the project with the problem.
The purpose was just to show the cross-section.
shapr3d_export_2026-01-25_13h22m.shapr (3.5 MB)
Now I understand the problem. Unfortunately it’s physical impossible to apply same radius on different angles and expect they look the same.
But if you apply different radius on a different edges smooth look can be achieved:
