Augmented reality angle
Trying to use the AR, and having issue with getting model to align with image seen by camera.
When in AR mode, I can rotate, align model for desired angle, but when I switch to AR object switches back to original angle which in this case is 90 degrees from desired.
Is there a detailed tutorial on using this function?
Turn your model in shaprd before you export it as USDZ…. Make sure the front view is the front view
Thank you
Fun to play with
