Autocad versus shapr3d
Hello to all,
I have a short question: is whorty to use Shapr3d if i use autocad since 20 years,?
I tried today to draw a simple building but….seems that this software is …weird.
My first ideea was to draw quiker…but seems impossible.
What is your advice???
I’ve used autocad for several years and shapr3d for about 3 years. I can say with confidence that Shapr3D is ALOT quicker for simple drawings. Depending on the complexity of a model, my workflow entail initial modelling in Shapr3D and then if i need functions not in Shapr3D, i simply export the step file to do further editing.
For me, I use AutoCAD for large-scale engineering, blender for rendering/animation and Shapr3D for everything else.
Further, I think Shapr3D is the undisputed best on-the-go cad program. So if you want to work on your ipad, Shapr3D is a no-brainer.
Lastly, if you know how to use AutoCad then I believe you will learn the basics of Shapr3D in no time.
Hope that helps!
