Tried to replace face now have this “copy” of my model which i cant do anything with, cant turn it off, cant move it, cant select it and cant delete it. Everything is supposedly turned off in the tree.
it did give me an error message and i tried undo which does work but the model shown remains
i found out that if i shut shapr3D down and reopen it the body disappeared, it’s done it a couple of times now, in the same area of the model.
Seems to be a glitch in replace face command, but i have worked round it now, and know what to do if it does it again
i cut out the problem area with a square cut and then remodelled it cleanly.
Thanks for the usual wonderful support, but you can close this.
I have seen this happening a number of times in the past 2 weeks. Always after a Replace face. I got the message “Something went wrong but your design is ok”. What I did then, just to be sure, I exported the design and started a new design in which I imported the earlier export.
