I use Ipad pro M4 13" 1 TB.
I can’t change the parameter value. I have to exit and reopen my design to make it work. However, it happens every time after I use it for a while. Please help.
Sali @Terbaik
Sometimes I also have such problems or similar.
At the moment I am making a kitchen with Shapr3d.
And I also own an I Pad Pro M4. In part, I also have a graphical problem with extruding bodies on the iPad Pro. And it can be strange to me.
Then I opened the file with my Mac Book Pro with the 4max, and lo and behold, everything worked better.
My thoughts are: it may be that the iPad Pro has too little computing power. But that’s just a theory. Maybe you can ask the support team.
With kind regards
Andreas Desiderius Haudenschild
