In Settings > Data Settings the “Done” button and the “Return to Drawing” buttons do not work. Required shutdown to clear
Hi!
Could you give some more information about the issue?
I need the following to investigate:
- The app version
- The OS version
- The device you are using
- A short video or steps which you took before the problem happened
If confidential, you can send all these directly to me at laszlo.korodi@shapr3d.com
Thank you!
