Cannot separate sketches
I am totally beginner so sorry for the question in advance, surely I miss a basic concept here.
I made the mistake to create sketches on the same plane and now I try to separate them afterwards.
I saw a forum discussion about this where they suggested to project them to a separate construction plane and then place them into a folder.
However, when I translate the separated sketch in level with the original sketch-monster, it jumps out of the folder and joins again with the sketch-batch. What do I miss here?
It is very awkward not to be able to select multiple sketches at once by drawing a rectangle around the sketches and that I cannot group them freely.
Thanks for your thoughts on this,
@isogulaleb
Please Sketch a small Circle or Rectangle, using the appropriate Tool from Sketch, on a vacant area in your Sketch.
Highlight the Closed Shape just created [Circle or Rectangle] and use Add > Construction Plane > choosing the offset option.
When setting the Offset distance choose 5mm or 1/4".
The Construction Plane will be created the distance chosen from the Plane with the Sketch.
Use Transform > Move/Rotate > Select the parts of the Sketch you wish to separate and Move them, using the appropriate Arrow in the same direction and distance as the Construction Plane.
I realise this will sound rather complicated and so I will provide a Video Clip to assist:
I have used two simplified Sketches and used a Rectangle to create the Construction Plane.
Planes MUST be separated in this manner.
Separation can be a little as 0.001mm or as far as you wish.
In Items to the left hide one of the Sketches to observe the result.
If you need more help just shout.
Thanks. And I suppose there is no way to tell which sketch is ‘attached’ to which plane, right? I should create 20 different sketches (see attached pic), this means 20 planes… I think this is not the tool to work this out :confused: S3D was excellent to work out the body but I feel I go back to good old CorelDraw to draw these…
Anyway, thanks for clearing this! Cheers!
@isogulaleb
I am also a CD User back to v4.
It will require a mindset change to work with S3D and new workflows may be required, it comes into it’s own with Bodies [3D Models]
Looks like you already have a ‘filing system’ running in Items.
As you say each Design is kept on a different Plane in a Named Folder, a great start.
This can be further expanded by using Files.app [iPad has this built in] and Designs are shuttled using Export and Import.
Much will depend on how you use your Sketches.
Ah, now I can start again from scratch… my two weeks trial has just finished and I cannot export anything… :tired_face:
Anyway, thanks for your thoughts!
You are most welcome.
The ideal situation would be to create each of your Designs and place each one separately in a .shapr File.
These Designs would contain the Sketch and Body or Bodies generated from that Sketch, and then placed into a structured Filing System within Files.app.
Only the Bodies are needed to create a combination Design., Export - Import works faultlessly and is efficient.
Take care, stay safe.
