Hope someone can help I seem to be running around in circles in the pic you will see that I have 2 sketches. These are 2d on the same plane representing a sheet metal part
In the part highlighted in blue I want to group the 3 sketches and lock them together in 1 part then move them to a new folder as a part on their own
The problem
1 I cant see any way to group items together without having to select each component each time
2 I cant see how to then either copy and paste to a new folder or move to new folder
As can see in the drop down menu I have over 400 sketches in one folder all on one plane.
It would apear that if I select a new plane then a new folder is created
But how do I force that to happen when I’m working in the same plane
I appreciate there must be a simple way to do this. Or a work flow process I need to follow. Or a way to hide sketches that I’m not working on. But that looks like its only available for different folders. So how do I move to a new folder or a specific part folder
All while working in the same flat plane not 3D at this stage. Cos I need to draw all the sheet metal parts first
