Cant align a sketched circle to a 3d object circle
I have a 3d object with a circle and I want to make a new sketch on top of it, then draw a circle that is aligned to the 3d object circle. Whatever I do i cannot get to align the sketched circle properly. It seems like the snapping is locked to the square around it only. Is this a limitation in the program? Am I doing something wrong or could this be a feature request?
I found a workaround using offset, it can make the circle from the 3d model smaller and give me cross hairs for alignment. But why can’t I just align the sketched circle with a concentric constrain or snapping? It would have been much easier…
Video:
If you select both the sketch, and the body edge, you are able to use concentric constraint. In you video, you didn’t select the sketch, just moved it’s midpoint.
Perfect, thanks!
