Can't edit step file
I have a step file that shapr3d cannot remove a object from. (See attached file)
qqqqqqq.step (2.6 MB)
FRONT you’re looking at the outputs of the ‘airhorn’
from the TOP view you will see a coin sized artifact that bisects a mount ear. That disk cannot be removed, move, deleted, resized etc in Shapr3d.
In contrast Onshape has no problem selecting it as a single object, moving it and/or deleting it.
How in Shapr3D can this disk (artifact) be removed from this airhorn assy?
It can be deleted. I gave the disc and the horn different colors just to seen more easily. Then I moved the disc down and deleted it. I could have left it in place and deleted it as well.
This STEP file is quite odd as it is hollow as far as being imported in Shapr3D. It is not a solid body. I’m unable to do a simple extrusion of the face of the mounting flange. I used Split Body to slice it in two areas to see inside.
double clicking to select it I get the whole air horn selected not just the disk.
Even from the items menu I can not select the disk by itself
ptegler
oh now that’s weird! I just downloaded and re-imported that step file I linked above, and THAT copy allowed me to delete the disk! I’d just tried it on my Ipad and the file worked as described above where I had been working on my windows desktop. I sync’ed and fired up my ipad and had the same non-op situation. so DNL’ed the copy above and it works as expected. VERY odd.
