Capsule, pointy ends
Hi, trying to create this capsule…
main volume is quiet easy.
But how do you make this “pointy” ends with the revolve tool ?
Any idea ?
1002469-alu-ohne-rollrand-pp28-gold_600x600
Just a quick and dirty design.
I let the ‘thread’ run naturally into the skirt section…
If I were to do this properly I would have given it the correct profile and wall thickness.
Nice try, never thought about that technic… :astonished:
Could fit for a long distance object, but not precise enough for my actual project… :roll_eyes:
That’s a shame.
If you do find a solution that fits your needs then please share it here. I’d be interested to see it. :ok_hand:
I thought what @welshsteve presented was spot on. I’m curious as to where exactly do you need more precision?
If you watch my original post, the picture shows less rounded elements…
With @welshsteve trick, I was also not able to add round edges inside the elipse (not sure my explanation is correct… as my English is maybe not good enough…) :roll_eyes:
:slightly_smiling_face:
