Chamfer angle
is there a way to adjust the angle in which and chamfer removes material? I am trying to duplicate a microphone stand. It has a long but shallow chamfer in it. My fillet tool pops up the second adjustment option for modifying it further. But my chamfer does not
Yes. You can set the length of chamfer for each side, not the angle directly.
Hey really appreciate the reply. Thanks for guiding me toward the two distance chamfer.
Is there another way to do it. The 2 distance chamfer got me closer but no cigar.
Here is what I am modeling for practice, and what I’m running into in shapr
The angle on the stand starts at a 4mm height from bottom. That is a separate section in my build currently hidden. So my remaining distance is 11 mm. The rest of the model is a 16mm chamfer but the back has the steeper sweep where the microphone mounts into the stand.
Do you have any ideas on how to model that back chamfer? If I bring it in past 16mm it starts removing material
Loft is the better way to go here IMO.
Thank you so much. Had to set it up different but this is a much better result!
