I’m on the iPad version…
This changed a few years ago, but I’ve never understood what’s happening or how to fix it. I’m trying to draw a line, then rotate it around the origin. However, when I switch to the Move/Rotate tool, it says the line is locked. I see a constraint, and delete the constraint, but I still can’t move or copy the line.
I would love to understand WHY this happens, and would appreciate help in figuring out how and where it is locked, how to delete the unseen constraint, and maybe even shut this feature off altogether.
I usually create a construction plane and draw the lines, but it’s an extra step.
I see the constraint on the top, but I don’t have any other constraint on the line, unless I’m just not seeing it. Is my issue also related to it trying to draw on the face of the object?
I don’t think so. The bottom constraint isn’t a regular constraint — it’s a connection. It doesn’t appear with the usual constraint icon, but you can see it if you select the point.
