The default for using a comma or period as the decimal indicator appears to be tied to the choice of units (metric vs imperial).  In the US we use both imperial and metric units, but we ONLY use the period as a decimal indicator.  Please allow the user to choose the decimal indicator rather than assuming that it’s correlated with the choice of units.
Nothing.  It’s simply a nuisance.
No.
