Will you guys be adding ability to create advanced curvature where edges meet and resolve like in the example shown (see attached. example shown is from Fusion 360. I’d add additional images comparing it to
what I mean in Shapr3d, but it seems I’m not allowed to)?Is the middle square extrude is smaller than the base geometry? Or are the edges tangent?
@Gelphyn genius solution. Thank you for the insight!
I there a tutorial somewhere that shows the best way to build tubular weld assemblies
In s3d
I’m trying to draw the 3d version of my oven supports made out of a stainless steel 25mm x1mm thick box section
Is it best to draw the whole thing as lines and then sweep them
Or actually draw a box section and extrude each section
A common practice approach would be helpful
Even if we start with just a frame for a cube
I can hopefully work from there
Jay Emery
