Is there a way to connect the two sketches or layers? I want to model a pipe. In the other image, someone did the whole thing using Fusion. Can Shapr do that as well?
FunktionenTest.shapr (15.6 KB)
I have no clue how you did that. I’ve tried but kam draw two lines like you did. Could you make a video of it.
Or another way
That works fine. Thanks a lot.
is there
Also a way to make it smooth? When you extrude the circles on both ends, it’s not really smooth
