Constraining sketches relative to other sketches
I’m new to Shapr3D on iPad. I have a hexagon sketch and want to place a circle constrained to a construction line between the midpoints of the top and bottom hex. Is there a way to constrain geometry in a new sketch to an existing sketch? I’m very familiar with Creo and Onshape, and those programs it seems you can constrain a second sketch relative to construction lines or other features in a first sketch or features of an existing extrusion, for example. Is it possible or am I just missing some simple functionality?
Basically what I’m trying to do here is extrude the hexagonal surface, and then have a circle extrusion on top of that, dimensioned from the center of the hexagon
Not sure why you want to use different sketches for that but you can constraint your circle to the line using midpoint constraint.
