I’ve drawn a floorplan in Shapr3D, using construction lines for the spaces where doors go. (I did this so I could make multiple wall segments all be parallel and coincident — I couldn’t figure out how to do this any other way.)
Regardless… I’m stymied trying to turn this into a 3D space.
I want to add wall thickness. I’m trying to use the Offset tool, but that’s not working even a little bit.
What is the proper workflow to accomplish this?
Thanks.
