I have an object that I’ve created that has an ‘odd’ size hole in it. I need that ‘hole’ duplicated in another portion of the object. How can this be done?
So is this not possible to do in Shapr3D?
Not sure what you mean by “odd size hole”. Have you tried patterning it?
Here’s the file that I’m working with.
I need to duplicate the elongated hole that is in the ‘left’ part of this object, onto the ‘right’ part of this piece (positioning it below the large hole).
Test1.shapr (342.4 KB)
The best approach I can think of is to add a sketch to the face with the original hole, extrude the hole’s profile as a new body, and then use that body as a subtract tool where you want the second hole.
I tried using Transform–>Rotate Around Axis, with Copy selected, and it just seems to distort the ‘original’ elongated hole, rather than making a copy of the elongated hold that I can move over to the other face. I can’t get it to work like your illustration shows.
