- Yeayyyy! Got it to crash. Turned on show hidden edges with two-finger rotate disabled and could not turn my model.
Turned on two-finger rotation and it turned, then went back out of two-finger and it worked fine again with one finger.
We believe what may have happened is that you tried to rotate the model too quickly after exiting the menu. The model space is locked for a few milliseconds after you exit a menu, to prevent miss clicks. If you wait for a second after exiting the menu you shouldn’t experience this problem. Please let us know if this does not solve the issue for you.
