Create a hole for a nut?
Hi, how is the easiest way to make a 6-edge hole for a nut?
I want the nut to be stuck in the print. how do i do that?
47
Draw 6 connected lines touching a circle. Set the lines to be =. Extrude out the hexagonal shape hole, Problem solved. There are tutorials about this.
or you can now use the polygon pen located in the sketch menu :slight_smile: (might have to manually update the app, it’s in phased rollout)
