Hi All,
I design parts for motorsport and have been testing various CAD software and so far shapr3d is, for me, more intuitive to achieve what I need, apart from one thing I am struggling with.
On Onshape there is a feature called “Projected Curve”, this option you select the sketches on two different planes and Projected Curve will create a line in 3D space that is the Sum of those two drawings.
My question is how do i achieve the same thing in Shapr3d? As designing motorsport parts that are very flowing, I require a fix to this or will put the brakes on a current project until I find a way or software that works in this way.
As in the image you can image a sum curve of the two drawings in 3D space that can then be used in a Loft.
Kind Regards,
