I need curved pipe but the end dimensions are different so Sweep doesn’t work. The manual suggests using loft but that cannot be made to follow the curve (it connects in a straight line). I’ve looked on the forum but nothing I can find deals with this - it shouldn’t be a problem but it appears so! Solutions most welcome ![]()
You can use the sweep tool with one of diameter, after it tap one of the end, scale and use the shell…
If both ends are the same shape where one end is larger than the other then Sweep could work. Do the sweep then select the face to change and use Scale.
same time..
Yours is first, so……..you win!
Works too of course ![]()
Thanks for the suggestions. The ‘guided loft’ look useful.
