Hello
I’m a beginner, I created a hollow tube and I’d like to cut it in half
to see the inner canal
Thank you
Hi -
The specifics of the tube would help, but please have a look at the two options below
- Subtract half of the tube with a simple sketch, then pushpull the half of the profile
- double tap on top
-draw a line
-pushpull to subtract
- Move the grid to the middle, and turn on section view. You can either do this by using the existing views, or by putting a construction plane to the right place
https://support.shapr3d.com/hc/en-us/articles/360008543033-Section-view
https://support.shapr3d.com/hc/en-us/articles/115001857065-Construction-geometry
Great,
Thanks a lot
